Deletes an entry to an L2PT profile.
| profile profile_name | Specifies the profile that defines L2PT configuration for L2 protocols. |
| delete protocol filter filter_name | Deletes the specified Layer 2 protocol filter. |
Disabled.
Use this command to delete an entry to an L2PT profile.
The following example deletes the entry for "mylist" from my_l2pt_prof:
configure l2pt profile my_l2pt_prof delete protocol filter mylist
The following example deletes the entry entry for "mylist" from my_l2pt_prof that is in use by a service:
This command was first available in ExtremeXOS 15.5.
